Help with gauge cluster wiring
jim1131
35
Illinois
Trying to figure out the missing wire numbers for my gauge cluster which had been cut by govplanet. I did look at the wiring diagram and the only wires which I think I figured out are the 2 wires next to 36A, I think they are 36B and 33 but please correct me if Im wrong. I would appreciate any help from anyone who is familiar with the harness for the gauge cluster with electronic speedo and can recognize the missing wire numbers from the pictures im posting.
NDT
6,537
Camp Wood/LC, TX
That is a nightmare. My only advice is to find the other end of the cut wire and connect one probe of your ohmmeter to it and check each cut wire for continuity. One wire will end up at the fuel tank sender, one at the oil pressure sender, and one at the temperature sender. One will have +24 with light switch in service drive. One will have +24 with highbeams on. One will have +24 with ignition switch on.
