Help with Heater core problem on my M1123
53
41
NORTHEAST WYOMING
Hey guys,
I am trying to understand why my heater doesn't work on my M1123. I never managed to get it to work since I got the vehicle from GovPlanet.
Not sure If am missing any secret manual shutoff valve anywhere... or what?
It looks like the shutoff valve connected to the pull out knob is turning fine.
Maybe the heater core is clogged and needs a good flush cleanup?
I appreciate the help as always!
Thank you
Lothar
659
North Arkansas
It's not too much work to remove the heater core. I recently replaced mine. If you think its clogged up, I would remove it and try running water through it. Also, since it's out you can pressure it up and check for leaks with some soapy water. The older they are, the more prone to leaking. I was a welder in the military and repairing radiators was a large part of my work. These things are cheap and small so easier to just replace them.
juanprado
2,841
Metairie/La (N'awlins)
There is the out side possibility that a shut off was installed or hoses tied together as a quick fix around in case of a leak.
Also look at the heater control valve to make sure it is operating correctly.
Pop the hood open and give it a good look see over all the heater components
AAVP7
261
Dortmund, Germany
I once stumbled upon a heater control valve that looked completely identical, but worked "the other way around". With the knob pushed in, the valve was open and let hot water through, and when you pulled the knob out, it closed. Probably a chinese knockoff, and while copying everything, they had the blueprint upside down....
86humv
496
Texas
I've had the valves that work opposite ...they are 2.5, or 5 ton truck valves.
53
41
NORTHEAST WYOMING
Hey guys,
I cleared the heater core still in the vehicle with the hose from both directions and it worked! A lot of stuff and debris drained out and some small stones, probably buildup of corrosion and rust.
Besides that everything looked great! I was really surprised how clean the coolant was considering last time it was replaced was probably 12 years ago in 09 according to a note I found on the engine.
Thank you very much for all the help! Me and the wife are super happy to have heat in the cabin. Especially my wife! :)
