help with my vacum pump :/
iamspencer
Roxbury, CT
does any one know what vacum pump will fit my cucv 6.2l the one listed for the civy version has a differnt gear shaft and doesnt seem to fit
thankyou for any help
happy 4th
iamspencer
Roxbury, CT
thanks so much
both those ones in the pic look liek the new one that iput in
the broken on i took out look differnt
anyway i pu tthe new one in and shifing improved some but still not really wantign to shift when it should
any ideas
-spencer
CCATLETT1984
Saint Clair Shores, MI
replace the rubber lines, both from the pump to the regulator on the side of the injector pump, and from the regulator to the transmission.
if that doesnt help, you may need to adjust the position of the regulator, loosen the two screws and move it a little at a time, one way will raise the shift points the other way will lower them. Can you tell me what speeds the trans shifts at? (driving normally not heavy footed)
