- 112
- 68
- 28
- Coppell, Texas
Currently in the process of disconnecting a Red Dot to move it farther back to our new 4 door rear curtain, and can't seem to identify some of the parts I'm looking for.
The condenser loop, #1 in the first photo of the inside unit (where the transducer attaches) is leaking oil all over the cab. I've seen several out there but they're all lacking a fitting for the transducer.
I'd like to at least know if I can get part #2 in case its damaged when we pull and replace hoses too.
The button with the arrow labeled #3 almost looks like a circuit breaker, but its loose and falling into the unit.
Lastly, what is the best hose to run on these things? The Aeroquip hoses I have now are completely rotted out, and I cant clearly see size and complete markings on any of them.
On the outside, I'm not a fan of how they mounted the dryer with one hose clamp, tightened to the point it's bent the upright on the red dot mounting bracket. Also trying to identify what the proper dryer is for this unit. Overall, just trying trying to clean everything up before it's all reinstalled. Thanks guys.
Like
Comment
Like
Comment
