- 150
- 35
- 28
- Burtonsville, MD.
I purchased a military run flat tool several years ago from a swap meet. I tried using it for the first time today. I am not sure if I am doing something wrong or if the tool is broken. I have tried winding it in both directions and it does not build tension. I can push on it and it the strap comes loose. It is not compressing the run flat at all. I am trying to install the same rubber run flat that I removed today using an engine hoist back into the same wheel it came out of. I can see the gears are not stripped or slipping at all. The slipping is where the strap is connected into the metal inside that spins when rotating the handle. Hopefully it's operator error. I am not sure what I may be doing wrong of if possibly the strap is installed incorrectly to allow tension with the parts inside of the tool.
