ida34
- 33
- 48
- Dexter, MI
I was looking under the hood of my newly acquired Deuce and I noticed that the temperature sending unit for the ether injection has one terminal connected to a wire running toward the firewall. The other has part of a solderless connecter. It looks like this was a broken connector to connect this to a ground. What are the connections supposed to be for the ether injection temp sensor? I don't want to just try it out on ground without some imput from someone that knows. The injection system does not seem to be working but I still need to check the cannister to make sure it is not empty. Thanks for any help in advance.
Chuck
Chuck
