HEMMTT Whells on a M123/M125 10 ton truck
73m819
319
gainesville, ga.
i dont think so, the 123/125 has 24" rims that fit over very fat drums( i would guess about 22"), also the bolt pattern is bigger so is the center hole
houdel
9
36
Chase, MI
Re: RE: HEMMTT Whells on a M123/M125 10 ton truck
M1075 said:
You might look into PLS rims. 11" pilot hole, 10 on 13.25" bolt pattern IIRC
What are PLS rims? IIRC the bolt pattern is the same as given in the M123/M125 TM, but they didn't give a pilot hole diameter. A rough tape measure job on my front hubs puts my pilot hole at about 10-3/4". That might work, to the best of my belief the pilot hole does not carry any of the load (in fact there is about a 1/8" gap between the pilot hole in my rim and the front hub), it is just there to roughly align the wheels to fit the studs through the bolt holes. I believe all of the vehicle load is carried solely by the wheel studs.
If I am wrong, somebody please correct me!
M1075
Oklahoma City
RE: Re: RE: HEMMTT Whells on a M123/M125 10 ton truck
Lee-
The PLS rims are from the M1074/M1075. They have the larger pilot hole and bolt pattern that probably matches your truck and the M911. I have found that HEMTTs, M915s and 5 tons have the smaller bolt pattern and smaller pilot hole.
I don't have a 10 ton, but I expect your rims are stud centric. If you have inner and outer lug nuts on the rears, you have stud centric wheels. They should have a slight bevel at each bolt hole, used for centering the rim on the studs.
I would look at trying the PLS rims, especially if you want to try running singles. The 16R20s might be a good fit.
BKubu
1,123
Gaithersburg, MD
If anyone needs any, I have eight 85%+ Michelin XL 1600X20s mounted on the correct HEMTT rims. I've seen guys put these on 5 tonners. If anyone is interested, I'd sell the whole lot for $2,520 (what I paid...$2,400...plus tax). That is a little over $300 per tire/rim. By the way, my estimation of 85%+ is a very conservative estimate...some still have mold seams. I just want to make sure whoever buys them is happy.
houdel
9
36
Chase, MI
Re: RE: Re: RE: HEMMTT Whells on a M123/M125 10 ton truck
I that the M1074/M1075 rim? If so, I would be interested.
Lee
M1075
Oklahoma City
Lee
No, the HEMTT and PLS rims are not compatible.
Aside from the bolt pattern, you also need to be concerned with the hub size. The M915 series trucks have 24" rims with the same bolt pattern as the 20" HEMTT rims. However, the 20" HEMTT rims will not fit on the front without machinining the hub. I would pull your front wheel off and measure the hub. I think it needs to be 19.5" or less, IIRC.
