HEMTT Detroit 92 Series 8 into 5-ton
Csm Davis
393
Hattiesburg, Mississippi
Saw one in a 809 series truck one time so it should fit the 939series truck fine. Well maybe check the width the side panels wouldn't close because the valvecovers stuck out to far. :eek::what::D
poorman4x4
-1
Lafayette, Louisiana
Don't even waste your time, if you want Detroit go 60 series, want a direct/more power swap cummins 400 big cam I-III, 8v92 requires gearing and power transfer your 654 Allison is out of the question, you go HT Allison series your adding close to 2000lbs in drivetrain weight
