HEMTT Fuel pump
toudi
San Clemente
Hej Guys
Hemet fuel pump is left hand or right hand , I need to replace it, and I forgot to check the stamp on pump. Truck is couple hours from me, and I would like to order new one.
Thank you
74M35A2
315
Livonia, MI
Do you remember what side of the blower drive the fuel pump is mounted on? Worst case, you could look up a HEMTT engine pic and find that, then determine it, as long as the engine is standard rotation, which it should be in most road applications that are not transverse mounted across the rear of a bus.
