HEMTT PCV setup
Augdog1964
15
Richmond, IN
Hey guys...
Well my HEMTT showed yesterday... M985... what an ordeal on EUC!
Besides some body dings and dents and a few paint needs, she looks pretty good...
I do have one question... it appears that there is a hose out of the top of both manifolds, that wraps down around the engine... and may go back up to the other manifold top on the other side of the engine.
I imagine this is the PCV... it appears that the hose may have been broken at the bottom as this should be a closed loop correct?
Or do these hoses attach to something like a catch can? Any idea where I can get this hose or assembly?
Also need the two sheet metal covers for the inside, between driver and passenger... that cover the switches etc.
Thanks!
JDToumanian
14
Phelan, CA
Those are just "road draft tubes", or crankcase vents if you prefer. They are supposed to be open, one hose to each valve cover. You should never really see anything coming out of them... Even a clapped out old Detroit will not generally show blowby there. The reason is that if combustion pressure is leaking past the rings, it does not make it to the crankcase... It ends up blowing back through the cylinder ports into the air box. When Detroits are clapped out, they let you know with oil slobber out the air box drains. A little is normal, a lot means overhaul time.
Jon
JDToumanian
14
Phelan, CA
Congratulations by the way... My EUC cleared yesterday, so my HEMTT recovery trip is coming up next week!
Jon
