Hemtt vs combat vs normal rim identification?
SandBar
Full Time Patriot
756
231
GA/FL
Hunting for 2 more combat or hemtt rims for my m817. Could use an example photo of each and how I can easily make sure a rim is either hemtt or combat (and not a non bud style rim). Been searching on marketplace and don't want to waste any sellers time. Thanks!
Elk1111
485
Las Cruces NM
Looks like an LMTV rim and probably only has bud style on one side. Combat rims have 10 bolts, LMTVs have 20 and I believe Hemitts have 17.
SandBar
Full Time Patriot
756
231
GA/FL
I appreciate the explanation. That means this is not a combat rim?
SandBar
Full Time Patriot
756
231
GA/FL
Great info, thanks. I read this :
"you will need to change you wheel studs or do thimbles on the from if you run HEMMT's."
Now I am confused. I need to change my wheel studs to run them up front?
gringeltaube
Staff Member
2,519
Montevideo/Uruguay
Studs should always protrude a couple threads, sticking out of the nut.
Both halves of the HEMTT wheel have their own center plate, about 10mm thick. Bolted together it's over ¾", a lot more than the thickness of the stock 5ton wheel center.
So the original stud ends up being about ¼" too short.
SandBar
Full Time Patriot
756
231
GA/FL
Interesting. Any idea where I could get studs for my old truck and what the part number might be? Terrible to replace studs on these?
Elk1111
485
Las Cruces NM
Dang..didn’t notice the different centers on that first rim. I’d just put combats or LMTVS on the front. You just can’t turn quite as sharp as with the Hemitts
