PeterD
- 6
- 0
- Jaffrey, NH
Here is a tough question, hopefully someone knows:
What is the path that the oil follows up to the rocker arm shaft? I don't see an oil port from the block to the head, and I don't see clearance on the head studs, but suspect it is allowed to travel up the head studs that hold the rocker arm shaft to the head. Can someone there confirm, and is there any cleaning needed if it is at the studs to ensure there is proper lubrication for the rocker arms and valve train?
When the engine was (last?) built, someone had put sealant on the head studs at the block (that's all wrong, IMHO!) I don't see oil starvation signs, however.
