HET Convoy Light on FMTV
NDT
6,486
Camp Wood/LC, TX
Since the correct warning light for the FMTV is unavailable, I thought I would see if one of the available HET convoy warning light kits would be suitable for the FMTV. Seems like the HET kit was made for the FMTV as well. See pics, the bracket has a notch that fits perfectly around the roof seam on the FMTV cab. Riv-nuts will need to be used to attach the bracket. Clintogf and Suprman have these kits. Unfortunately, the Cannon connector on the HET kit is incompatible with the FMTV, but that can be replaced. There is a thread here with the part number for the connector.
agazza2
31
Ahwatukee, AZ
I'm planning on putting a pair on my new tractor. I got the plug from pei for 20 bucks.
Do you have the Amphenol connector number you used, and what is PEI? Mine is mounted, just trying to find the correct connector for the FMTV.
mkcoen
381
Spring Branch, TX
Got mine last week but waiting to get the truck back from the AC shop. I need to install that, start working on the insulation, and get the new tires swapped on and then I should be done for a while.
