HF Paint Pot & Spray Gun
randygk
Nampa, ID
FYI the Harbor Freight paint pot, at about $ 100 for the pot and gun with 25 ft hoses it works quite well. The regulator that comes with the pot should be immediately thrown in trash and replaced with a decent one. Just needs one or two tee's to mount. Check small packing nuts on gun for tightness, on the pot gun and gravity feed gun they came off while spraying. You should use a liner on the pot, a Binks 2 gallon liner almost fits, you just have to trim the top edge with razor or scissors. Putting Xylene or acetone in the pot will cause the coating to peel. Also makes cleanup a snap.
The gravity fed gun works quite well, as noted in other posts.
Painting M35A2 with Rapco 34079 and bought the paint pot to do under the bed and frame.
