- 327
- 51
- 28
- Bakersfield, CA
Over the past few years of owning my deuce, power steering was always on the top of my list of things I wanted to upgrade. Finally, after several months of research and looking over the options, I opted to go with the HF54 route pioneered by Gringeltaube. Another member, local to me, Seth-O was a big help in the whole process. I also had a few emails back and forth to Steve6x6x6 about pitman arm choices for the HF54. He also did an excellent write up. You can view their threads here:
https://www.steelsoldiers.com/showthread.php?114451-Ross-HF54-Power-Steering-in-my-Deuce (Seth's)
https://www.steelsoldiers.com/showthread.php?2909-Deuce-power-steering-conversion (Gerhard's)
https://www.steelsoldiers.com/showthread.php?15916-Power-steering-for-the-Deuce (Steve's and Gerhard)
I decided I wanted to go with the HF54 conversion because the box sat inside the framerail, like the originally equipped manual steering box. At the time when I was planning this out, I was running 395/85R20 Michelin XZL super singles and MRAP wheels. However, I ended up switching these out to 1100R20 G177's to get back some of the original deuce look. I felt I was getting too far away from the original look, as this truck is used in a lot of Veteran's events and honestly I like the dualed out look better. I think the G177's are a great improvement over the stock 900's and handle better than the 395's, but YMMV.
I did ponder full hydraulic steering, although proven reliable, I live in bleeding heart, sue happy California so I wanted a fail safe in case of a complete hydraulic failure. If I got in an accident and CHP/DOT found out I was running non-highway approved full hydro steering on the road they'd have a field day on me and open myself up to endless lawsuits (not to mention give all us MV owners a bad name/reputation). The HF54 does has the capability to be ported for hydro assist lines, perfectly legal and also useful for a hydroboost brake system, if I ever decided to do that, although I haven't really seen many of those conversions. From the write ups I've seen on the HF54, even with the wide singles, it has no problem moving them without needing hydro assist. Maybe I'll rig a steering sensitive beer can crusher to it, who knows.
So over the past 6 months, I have been acquiring the parts to do the job from various sources, mostly a popular auction site we all know and love.
I was ready to start my project, so all I needed was some time, not easy as a teacher and father of 2 and all the stuff that comes with running a household and such, but as a teacher summers are great, however in CA they are HOTTT!!! I wasn't really looking forward to doing this during the summer (My truck lives outside), but it was probably my most viable option. I made sure I had everything ordered in time for the break!
- I was able to find a Ross/TRW power steering box, HF54 series, part #542996 for $200. It said it was rebuilt and nicely painted when I got it, well, more on this later. Being that these boxes are pretty much obsolete, I went ahead and ordered a rebuild kit for it. This was $50.
- I found the pitman arm for it from 99 Truck Parts (Canada). Part number D0HA-3590-J...this was $100 shipped to me, appeared in brand new condition. This of course was shortened to 7.5" center to center as Mr. G pioneered in his thread for the optimum deuce rotational capability.
- I made my own drag link by using a few tie rod ends from a 70's Dodge truck. Part #ES304L and ES304R, right and left hand threads. I found these fit the pitman arm and stock deuce steering knuckle (which was retained from the original setup) perfectly. I picked these up for a steal at $20 for BOTH!! To connect these together, I went to the steel yard and found a piece of 1" solid round bar (~$20), welded on adjusting sleeves on each side (Moog ES3420S, $18 each). One side had the LH thread open, the other side had the RH thread open to accept each TRE respectively.
- Since mounting this PS box required cutting/trimming the frame, I had to make a reinforcement plate, similar to Seth's and Gerhard's. I took a piece of 8" channel, 22" long, and cut off the lower leg to create an "L" shape. This cost approximately $30. For the mounting hardware to bolt this to the frame and to bolt the box to the plate, was about $50 from my local bolt supply house. I did have to purchase an 4" hole saw from home cheapo to cut the hole for the large sector shaft, as it protrudes into the frame rail. This was $22.
- I was able to purchase a PS pump from a 5 ton, 800 series engine from another SS member, Capriceii, $250 plus shipping. This is the same pump that Mr. G, Seth, and a few other's have used. I believe it is also the same pump that the Waterloo kit uses. 1500 PSI and 5 GPM.
- For the steering linkage, I used a 24" "DD" telescopic steering shaft made by Borgeson. Part #450024, $77. To connect it to the upper column, I used a Borgeson 1" smooth round X 1"DD U-joint, part #015268, $65. To connect to the box, I used a Unisteer #8050880 3/4"-36 spline x 3/4" DD U-joint, $68.
- The upper column is a Gama Goat column. This allowed me to retain my horn button capability without doing too much engineering. I was able to find this for $30 shipped, brand new! I fit the original, cut down version of the OE steering shaft inside as the GG column wasn't quite long enough and had a female spine on it, I figured it would be easier to use the original shaft and shorten it to accept the 1" smooth U-joint, the deuce and the GG have the same diameter shaft, 1" round.
- Of course with PS you won't need the 20" wheel, and to save some space in the cab, and my wheel was badly cracked, I splurged and purchased a new 18" 5 ton wheel for $100. My horn button assembly came apart in the process of removal, so a call to Big Mike's I had a new one for $20.
- For the reservoir, I used a Nelson Exhaust #91048A, $80. It holds just over 1.5 quarts, and according to research others have done this is plenty of fluid. It also has a built in, easily replaceable, reasonably cost filter you can get off the shelf at most auto part houses.
- 4 quarts of Type F ATF was $18 from Napa
- Custom hoses and fittings cost me $80 from my hose supplier.
- So, all in all, I had about $1300 into the system before I started. I did want to keep it under $1000, but I was satisfied I had just about all I needed.
