WatchDawg
- 0
- 0
- Baltimore, md
All,
History of issue
I've been having an issue it appears with the drivers alt. Gen 1 light has flickered since i have gotten it about a month ago. Then approx a week ago the headlights went out, tried to replace switch, had to run a cable from one battery to headlights to get em to turn on again.
Current state
Yesterday was running fine, took a 40 min drive prior to stopping for the night, and everything was working. This morning (was a bit cold approx 32 degrees with a 10 degree wind chill). Started up after a bit of effort (weak crank), and turned over, after waiting approx 10 min for high idle to go down, took off for close by store, got a quick drink, and it was dead. Got a jump from AAA, and even that didn't crank it, so did a spirt of ether, and fired right up. Got to work (20 min drive), turned it off, and tried to turn back on, and was completely dead).
yes I've read the TM's and the wiring diagrams, got em all in my google drive for quick reference when shopping or working on it.
What I have done so far -
Front front side battery, ran 12v cable inside cab (master 12v on/off). From that switch into a small terminal blocks to give 12volt to things that require them.
Replace lighting pull / push switch, didn't fix headlights
-headlights with an on/off switch and inline 30 amp fuse
-dome lights with an inline 20 amp fuse
-interverter with on / on switch and 30 amp in line fuse (2 built in fuses 15 amp) [taken out of line]
-got 2 nice new batt's put in back near the rear junction box so i can (eventually) charge off the 24v system and always be able to jump (as I would have needed to this morning)
lingering issues
-no gen light at all now for some reason
-using blackout light switch to turn parking and service lights on and off
-indicator (left right) relay stopped working this morning (couldn't multimeter it yet, was rushing into work, worked just fine yesterday)
Here is what I'm thinking of doing for next steps and would appreciate any feedback
-Head to parts store, pick up batt charger, charge back batt's and have em ready to go as a spare / jump. or at least so i can get a jump from anyone (jumper box on one, car on other)
-installing new alt on drivers side (Part Number:DL7157 ) will rebuild original and have a spare for $80. I think this will fix charging system and any latent issues with power, starting at source, I will run new wires from back of alt, on wed during major maintenance
History of issue
Current state
lingering issues
