High Volume/Pressure Oil Pump?
JAsher45
Redfield, Iowa
how much more pressure are you trying to obtain? the stock pump is more then capable of doing all it is ment to do.. if need be you can change the oil pressure relief spring in the pump to get the desired effect.... are you having low oil pressure issues? adding a turbo?
Barrman
2,238
Giddings, Texas
10 psi for every 1000 rpm is the old stand by to judge good versus bad pressure. Below that, start thinking bearings and pump. However, it is almost worth your while to get another 6.2, go through it and have it waiting. Then just swap it in when your other engine goes. Repeat and always have a spare.
