Hinge pin replacements for m101a2
1,176
More importantly, what do you plan to replace the Aframe attachment points with once it breaks from fatigue. They are not meant to dump.
Franki21
New jersey
Umm, you mean to say that the front bolts that hold the body to a A2 frame are not to be removed to use as a dump trailer occasionally?? Good to know,,
MWMULES
346
DESOTO, KANSAS
That is correct it was not made or intended to be a dumping trailer. It has been done but when it breaks the the casting at the pivot point it destroys the trailer.
gimpyrobb
dumpsterlandingfromorbit!
27,785
750
Cincy Ohio
Put a limiting strap from the A frame t9 the bed so it doesn't bind and snap the casting and you might be ok.
