Historian help ?
dragonwagon
west branch Mi
Im painting my duece with a color that is " late wwII " color . My question is this , being it is quite a bit lighter then the dark OD green did they still have the white star on the trucks when they switched to this lighter color at the end of wwII ?
Im painting it in sections . Sprayed the frame and wheels last night so here is a pic of the color . It is not much different from what was on it .
dragonwagon
west branch Mi
Thanks , i did research this , found several photos on google but then i realized they are repainted same as mine , so was it orginal or just the owners choice !
dragonwagon
west branch Mi
Of course you do know that your Deuce was not in WWII.
Yes im aware , Its a 71 .
I seen a couple trucks done in the dark semi gloss and just didnt care for the look so i picked this color . I do like the white star however . Apparently im not to far left field with this color and the white star/lettering .
dragonwagon
west branch Mi
Now whats the pros and cons to using flat white and a stencil v/s vinyle lettering . Im sure the stencil is much cheaper . Paint more setting of the time the truck was used .
paint of stencil set ?
steelandcanvas
85
Southwestern Idaho
If the vinyl lettering gets scraped or damaged in some way, you have to buy a new one. With the paint and stencil method, any damage is corrected with a rattle can. Just my 2cents.
