HMMWV body parts TM
Frost0071
Indianapolis/Indiana
Does anybody know in which TM you can find all the body part numbers?
In the 9-2320-280-24P manuals are some of the outside panel numbers but nothing from the inner structure of the body.
I have to replace some small panels and was hoping to find the numbers for them.
Thanks in advance.
Guyfang
26,614
Burgkunstadt, Germany
When ever you are looking at an exploded picture of something in the Parts TM, and it's not called out with an item number, you need to look farther. Every part is in there, and at least a part number is listed. Maybe no NSN, put at least a part number.
frank8003
4,989
Ft. Lauderdale, Florida
Every figure that has part call out numbers on it will have probably the next page giving all the information about each part. All the -P TM's are like that.
Are you trying to read TM's on a telephone?
Frost0071
Maybe I'm blind but I could not find the parts that I'm looking for.
I would like to replace the part where the control for the winch is mounted and also the panel in the corner
I also would like to get a new panel for the inner side of my a pillar
Are they somewhere in the manual?
papakb
1,196
San Jose, Ca
The fording panel is something that was made locally from some sheet metal and won't be in the parts manuals. The right A pillar should be in there and I obviously found it once because I bought one for my truck but I couldn't find it either. I'll look back in my receipt log and see if I can find the number there.
Found it: A Pillar panel, RH 12338652-2
Frost0071
Thanks that's perfect [thumbzup]
