HMMWV bypass oil filter plumbing
rcamacho
827
Bainbridge Island Wa
I'm looking to install a Frantz filter that I have languishing in the garage. Looking for suggestions on how to plumb the pressure feed and return feed.
For the pressure side I have been looking at installing a Tee in line between the oil pressure sender. However, I would prefer a dedicated connection elsewhere on the block or oil cooler.
For the return side, looks like I'll need to tap into the oil filler assembly or a dedicated fitting on the oil pan or valve cover. I've not seen a low pressure return elsewhere.
