- 5,252
- 3,968
- 113
- Charleston, WV
![ImageUploadedByTapatalk1351766827.266830.jpg ImageUploadedByTapatalk1351766827.266830.jpg](https://www.steelsoldiers.com/data/attachments/270/270275-ca6e2fd05139189582a53da3178607aa.jpg)
We ended up with about 7-8" of the heavy, wet snow from Sandy. Our road was a sloppy mess with tree limbs down everywhere and more branches and tree tops breaking off every few minutes. As you can see, a pretty good sized limb fell across my M1101 trailer. Thankfully, the trailer is fine outside of a tweaked soft top bracket. I decided to fire up the HMMWV to move it away from the big maple that was shedding limbs before one went through the hood or top. I fired it up and moved it up the road a little and then figured I would venture off of our road to see what the rest of our neighborhood looks like. The hill heading up out of our hollow is really steep, so I figured I may have a little difficulty getting up the road. I started out in 4H and got about half way up the hill before the rear end lost traction and started to go a little sideways. I put the brakes on and thankfully, they held after a little backwards slide. I put the t-case into low lock and after a good amount of churning the tires started to bite and the HMMWV began making forward progress. Once I gained a little momentum, the rest of the hill was no problem and I churned all the way to the top.
I'm curious to know how the rest of you guys do in the snow in your HMMWV's. I think most of my problem stemmed from the huge tread voids on the Baja TA tires and the deep slushy snow. A set of all terrains would have had better grip with the extra siping and smaller tread blocks. Any other tips to snow driving in a HMMWV? I think getting some more weight over the rear end will help with traction too. I have an airlift bumper, spare carrier, fuel can carrier and spare tire to add to the back so that should help get some weight on the rear tires!
