Mastherr
- 12
- 3
- Miami, Florida
If you need to cover your turret opening in the M1151-A1, I’ve custom ordered a 1/4” thick polycarbonate sheet and made cut to size. Not just that but also had it pre-drilled 12 holes to coincide with the turret’s existing screw holes.
There are 36 screws holes, for this purpose I don’t see the need to use them all, so I only used 12, which still provided a great “sealing” between the polycarbonate and the turret original rubber gasket.
See attached the template I’ve used to custom order it, it worked like a charm!!!
