HMMWV parts ID
Jones
Sacramento, California
Going through a box of NOS parts and I've got some wiring I'm trying to ID.
One is a four pin moulded female plug, stepped so that two are on a different level than the other two (so thay can't be connected incorrectly). Out of the plug are four 8" leads with number tags that look like they're in the range of a lighting circuit (458 is one I remember) These are NOS so I think this is a repair or MWO part, not what someone cut off of a harness.
Another is a small harness with rubber Packard waterproof connectors at one end. The other end has a GM-style Delphi connector and the package is labeled "TPS connector" (Throttle Position Sensor maybe?).
There are several that have a cannon plug on one end and a toggle switch on the other. They have a Kent-Moore label and are marked "analyzer switch" or something similar.
Last is a cable several feet long that looks like it has cannon plugs on the ends but the pins on the one end I can see are small so I'm thinking test set rather than trailer cable.
I don't need to be hanging onto stuff that's only glorified wire scrap but I sure don't want to junk out a part that might get someone on the road.
Anybody wanna help with the identification?
answered that yourself...
Plugs into the TCM on a 4L80E....if im thinking right...
read above
