Hmmwv proportioning valve question
Pstyckiewicz
165
Massachusetts
I have an M1152A1 that brakes fine when it’s dry out but add a little snow then the back end seems to slide out way earlier that expected.
Is there a way to adjust the proportioning valve or should I just leave it alone.
MarkM
CODE BROWN...It's all going to sh~t !
2,083
WOBURN. MA.
You could install a remote stand alone proportioning valve to the rear brakes with an adjustable knob and makes everything very easy. Have done this on equipment over the years.
Mark
Pstyckiewicz
165
Massachusetts
Haha I figured it was setup to have a bunch of weight in the back. I’ll have to loader up with some sand
Definitly like the idea of adding an adjustment
Pstyckiewicz
165
Massachusetts
A little more digging and I found something in the brake system called a brake pressure regulator. A quick google of what that is and it states that it is a proportioning valve. So my question now is where would I put the adjustable valve?
