HMMWV REV truck brake bleeding
M1028A1ShelterCarrier
68
Mammoth Lakes Ca.
So while rebuilding all of the calipers, I noticed that they contained a mixture of dot3 (green) and dot 5 (purple). I emptied the master cylinder to get rid of the junk fluid and applied a vacuum on the lines to get the remainder out. Now I have topped of the master cylinder with milspec dot5 and attempted to apply a vacuum to the back passenger side brake caliper. I am only getting inconsistent clean dot 5 spray out after a ton of suction.
I have reviewed the 24-1 and it only describes a bench bleeding procedure for the MC. So what do I do now? Pull it out or is there a shotcut? Or should I buy a kit to pressurized the MC? Thanks in advance!
mgFray
951
Southern Minnesota
Unless you truck has anti-lock brakes (which most do not), it SHOULD be standard two-person bleed. Start with rear pass (right)... Someone in the cab pressing the bake, someone in the back opening the bleeder, letting the air/fluid out, close it.. repeat until the far right has no more bubbles.. go to the rear left, repeat.. then front right, then front left.
I didn't completely service the lines on my 1988 when I got it, but I was able to clean out the fluid in the calipers and did go through a lot of silicone so I should have mostly clean fluid by doing it this way.
Mogman
8,902
Papalote, TX
I am curious, if you let what comes out sit does it phase out so you can reuse it?
TOBASH
3,244
Brooklyn, NY
I HAVE the military antilock brakes. Is there a different procedure to bleed them?
mgFray
951
Southern Minnesota
I have no idea on the military antilock brakes.
On the civilian vehicles I've worked on it's one of the following:
1) you bleed them the same way as normal
2) you need a fancy computer to tell the anti-lock brake system to go into bleed mode, THEN bleed as normal
3) (the neat one) you have a fancy computer and tells the ABS to bleed, the computer tells you which brake bleeder to open and it does all the work for you, you just open and close the bleeder as it tells you, one brake at a time.
Good luck.. as long as you are not disassembling everything, I'd hope that #1 will work for you...
