HMMWV seatbelt kit templates and adhesive info
steelsoldiers
3,972
Charleston, WV
Hi All,
I picked up a 3-point seat belt kit for my M998, but it didn't include the templates that are used to drill the holes in the body for all of the braces and brackets. Has anyone installed the belts without using the templates? It would seem that you could hold the brackets and braces in place and use them as the templates to drill the rivet and bolt holes, but maybe that's not accurate enough. Thanks for any tips.
Chris
jwaller
19
Columbia, SC
I installed the 3 point upgrade in mine, front and rear and didn't have any of the templates. it's not bad at all and if you have the MWO then you can figure out where they go.
The fronts can only go in 1 place, the rears you can move them around a little but not much.
I didn't bother with the glue either I just did rivets.
indy4x4fab
Banned
1,711
41
indy, indiana
If you guys need any more of those three point seat belts for the humvee drop me a line. I have a few sets ling around that I'm not going to be using now.
steelsoldiers
3,972
Charleston, WV
Thanks John. That's what I figured after reading through the MWO. I found the 2-part adhesive through my local NAPA. I am going to use it since I will have my kids' seats buckled in with the belts. Can't be too careful with them.
Stonewall
Peoria, IL
Did anyone come up with a template for locating the rear bracket? I have the tech manuals, and I used to have a 4-man, so I know really close where the bracket goes, but I would like it exact.
Crapgame
329
Navarre, FL
Hey guys. I can’t seem to get the attachments to come up. Just got my belts in. And trying to get her figured out.
Link to the actual 3pt Seatbelt MWO here; adhesive is listed above, as well as the photos of landmarks for bracket placement:
[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]imfmotorpool.com/074681.PDF
[/FONT]
