- 753
- 1,331
- 93
- Highland, Indiana
Trying to remove the hatch on the rear of my slant back and I can't seem to get the latches to open to remove it is there anything special?
Spray the crap out of the latches with wd40I pulled on the latch and I've got the rear hatch supported by a forklift but it won't release the pins.
Yeah I know they arent connected by any sort of linkage, but if the door is propped open by any substantial angle it might be tougher to open.The bottom is already unlatched. There is nothing that interconnects the two latches together. I'm going to try to spray them down with some lubricant.
Well theres your problem. That latch is still closed. Some lube and elbow grease and you should be able to pop it open.It keeps hitting his clip when I try to open.
