hmmwv1
- 1
- 0
- haines city fl
since i searched the internet for almost 4 hours and could not find complete instructions on installing this tachometer i thought i would post my install
the tach is a military issue tach made by dixson for the hmmwv.it is a 3500 rpm with an hour meter and light and does not have a pre wired plug(i bought it off the internet) made my own mount too
part number is 6680-01-474-0384
there are 5 wires to hook up
first is key on power- spliced off the power feed on fuel gauge
second is ground- connected to back of instrument gauges gound
third is light-spliced off of instrument gauge light feed
the next 2 wires are signal feed wires for the pulses,the tach drive in the rear of motor is where they hook too,it does not matter which goes where,they are just pulses and work the same if reversed
hour meter count engine running time
it would not work hooked up to the alternator a/c output,read 2900rpm at idle
hope this helps someone
.![IMG_1282.jpg IMG_1282.jpg](https://www.steelsoldiers.com/data/attachments/423/423272-ff7d0dcd5c95e0f3f3d8accaa51b612b.jpg)
![IMG_1281.jpg IMG_1281.jpg](https://www.steelsoldiers.com/data/attachments/423/423273-7ee3a82ef3dece9a2c252db8b883d496.jpg)
![IMG_1287.jpg IMG_1287.jpg](https://www.steelsoldiers.com/data/attachments/423/423269-ac3eaeb3998d068c6937a526d5ef5c02.jpg)
![IMG_1286.jpg IMG_1286.jpg](https://www.steelsoldiers.com/data/attachments/423/423271-7f79de626b87f42441cf86f1c57aa0a7.jpg)
![IMG_1285.jpg IMG_1285.jpg](https://www.steelsoldiers.com/data/attachments/423/423270-4b6f458c82b3a391e1412ea74c2c2cb7.jpg)
![IMG_1284.jpg IMG_1284.jpg](https://www.steelsoldiers.com/data/attachments/423/423267-b5429b28593e8ac4cea38d185cf7a77c.jpg)
