HMMWV tire squeal
Katavic918
54
Maryland
Is it normal for an m998 to squeal the tires when turning? The trans case is in H and it seems like the inside rear tire is squealing when I make a turn. Thanks for any info.
parklandtrans
Roy, wa
M998 Tire Squeal
Check all tire pressures and ALSO Tire Diameter...!! If one Tire is considerably smaller in diameter that wheel will be turning at a considerably different rpm...it's a real quick, painless and no real cost check..!!
Please let me know if this takes care of issue or not...😀
Bob/ Parkland Trans
Katavic918
54
Maryland
Got it figured out. It turned out to be the front tires making noise. They were towed out about an inch and a half. Got it adjusted and no more noise. Handles a lot better also.
parklandtrans
Roy, wa
Outstanding.....!!!...you now have taken care of the front tire alignment but what about the rear tire alignment..??
All HMMWV's are four wheel alignment by design...so if you had a problem with the front there is a good chance that rear is out of spec's as well. It's a lot cheaper to get a 4 wheel alignment then it is to keep replacing tires. You could be 1/8 -1/4" out of spec, not even feel it and within 50-100 miles you got 2..maybe 4 defective donuts. I know there's a lot of used tires but why not just get it done right and not have to fool with it ANY more..??..sound good..?
Most tire shops should be able to handle the real HMMWV's and H1's
Let me know either way my fellow Steel Soldier,
Bob
Katavic918
54
Maryland
You sound like an excellent salesman. Lol. All in good time. I'd like to get the major demons taken care of first. The rear tires seem pretty evenly worn so ill leave it alone for now. Thanks for the help.
