HMMWV vibration and noise when braking.
Kraz 255
ČR
Hi, I have an M1123, I'm dealing with vibrations and especially noise when braking. The brake discs and pads are like new, everything moves freely. The more I brake, the louder the noise - there's a clicking sound. Does anyone know? 99% sure it's not the brake calipers and pads.
It sounds to me like the noise is coming from the final drives on the wheels. Or maybe it's like the front and rear cardan shafts are clicking against each other. It sounds like clearances are being defined. Thanks for the advice.
MarkM
CODE BROWN...It's all going to sh~t !
2,063
WOBURN. MA.
CV boots okay? Is there oil in the portals? The hub nut for the axle tight? Are the bolts on the inner mounting flange of the axle tight? I would start with the above.
Mark
