HMMWV Vin Location ?
syclone93
Rancho Cucamonga, CA
I have only one question and it's simply a serial number location question. Obviously the AMGeneral Military Hummers have a Data plate with the 6 digit serial on the left "B" pillar. My question is whether or not that same serial will be stamped anywhere else on the vehicle. I am wondering how you would identify a truck should this plate be damaged or removed. Thanks
Lawdog734
186
Colbert, GA
I Google'd this and it appears that the data plate is the only place where you should find a serial number time after time. Occasionally you'll find the serial number on a tag wired inside the end of one of the frame rails, but these are usually missing. If it went through depot rebuild, or if it was missing at any other time - It's not out of the question that a plate would be removed from a wrecked truck and reattached to a different vehicle.
There is a body number on the shelf near the intake under the windshield, but this appears to be an internal tracking number and is not the serial number.
Now, because the plate isn't riveted with any special rivets (just pop rivets), if it should become damaged you can easily replace it with a new plate. I did this because my original plate appeared to be finished by a 5yo with a set of hand punches. I had mine engraved by a local trophy shop. If it should be removed, you should have it replaced immediately.
