HMMWV Wheel O-rings Civilian Part Number
GIJoeCzar
32
Sherwood, WI
If I order this:
3/16" x 14.00" ID buna N 70 duro (red) O-ring
... will I get the correct wheel O-ring for the HMMWV A2 12-bolt (13th hole) wheel O-ring p/n 12460338? If the above is correct, does anyone have the exact civilian part number for this O-ring?
I've done my due diligence searching this site, but I don't see anywhere someone confirming that the above information is correct or the civilian p/n for the A2 wheel O-ring.
Thank you.
coolboatguy
35
las vegas
I bought 48" of 3/16" oring material and made my own. One dab of superglue and you're done. Just make sure you cut the ends square but even if it's a little off it's still good because it gets squeezed. It's maybe a buck a foot.
Mogman
10,499
Papalote, TX
I did the same thing with some that were too long only I did not even glue the ends, one out out of five loses about 2-3lb a month, still stable after 6000 miles
Mainsail
1,801
Puget Sound, WA
According the NSN, the reference part numbers are:
12460338 (USATAC)
91610 (HAYES Int)
5331014171043
5331PL0654139
12460338 (AM General)
91610 (HAYES Akron)
RCSK17877 (AM General)
X91610 (HAYES Akron)
CROSS-SECTIONAL HEIGHT 0.192 INCHES MINIMUM AND 0.202 INCHES MAXIMUM
CENTER HOLE DIAMETER 14.420 INCHES MINIMUM AND 14.560 INCHES MAXIMUM
MATT MATERIAL RUBBER
MATERIAL DOCUMENT AND CLASSIFICATION ASTM-D-2000 ASSN STD SINGLE MATERIAL RESPONSE
