Hobart 90G20P
31
-7
Oshkosh WI
Diesel Engine Generator Set on Trailer
Supplier: Hobart
Part #: 90G20P
Part #: 90G20PTYPEA/M32A-86
NSN: 6115-01-061-6610
Current Type: AC
Frequency Rating: 400Hz
AC Wattage Rating: 72 kW
Line to Line Voltage in Volts: 115.0 and 200.0
Phase: 3
Accessories: 45 Gal Fuel Tank, Batteries, 3 Inch Lunette Eye and Cable Storage Bins
Length: 8.25 Feet
Width: 6.5 Feet
Wheelbase: 4.375 Feet
Ground Clearance: .75 Feet
Used On: C-141, C5 and B52 Aircraft during Ground Maintenance
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
XJ, 400hz is not good for much more than light bulbs and resistive heat. If you are really looking for 400hz stuff, I know someone that will hook you up for just about scrap prices.
jeffhuey1n
SMSgt, USAF (Ret.)
1,477
Laramie County, Wyoming
400 hz is used on many aircraft. You can probably get top dollar from an FBO if it's running correctly. If it doesn't work right, IMHO scrap it cause it'll cost a bundle to fix.
