Gunfreak25
- 620
- 113
- Yuma, AZ
The test was 2 pieces of sheet metal. We all know what sheet metal sounds like when you hit it. After applying 4 coats the undercoating the sheet metal went from sounding like.....sheetmetal.....to sounding like a dead, flat, vibration less piece of cardboard. Total night and day difference.
The recipe:
Behr exterior house paint (any brand will do)
Sand/gravel from the yard
Mix enough sand in to achieve a toothpaste like consistency (you know, the baking soda old school kind of toothpaste). Just thick enough to be brushed on and build up thickness quickly.
It didn't need as much texture as I put in there, that was all the gravel from the yard. When I make up a large batch for the cab I will be using playbox sand which is cheap and is rough enough for my liking.
This stuff works just as good if not BETTER than ANY off the shelf undercoating you can buy and is a fraction of the cost. The advantage of the behr being you can have it color matched to your desired shade.
I will be using black!
The recipe:
