- 711
- 982
- 93
- Southern Minnesota
Was wondering if someone had a point to diagnosing what might be wrong with the horn on my M998.
I looked in the service manuals and didn't see any flow charts on checking the horn wiring.
So far, I've checked AT the horn. I've got 24V where I should. The other line has no voltage (or -). I tried to check it with someone pushing on the horn button and nothing changed.
Wondering what I should do next? I assume at this point either the horn switch isn't grounded property, the horn switch is bad, or the column connection is bad, or the wire from the column to the horn is bad.
