Bcurtman
- 1
- 0
- Rosebud, Mo
My deuce just started this. I had some lines loose / off while bobbing it, and now the horn squeals until the air pressure gets to 30 psi or more. Very annoying! I disconnected the solenoid and tried to see if it was stuck, but my understanding is that the solenoid is always powered and closes on ground. Only other thing I changed was a line (that I am guilty of not chasing back to its origin) that was open and seemed to be venting air out of. I plugged it. It comes up the firewall on the passenger side and was just bent over. I wonder if it was originally connected to the air cleaner housing?? Horn works as normal once air pressure is up. Could I have connected the wires back to the solenoid incorrectly? Any ideas?
