hose and filter
1,177
RE: Re: RE: hose and filter
when I open the drain valve, nothing comes out.
Was the "ignition"/accessory power switch on when you tried to drain the primary fuel filter? Do you have a working in-tank pump? I have had to poke a twig or something into the petcock on occasion to get it to start flowing. If you do a search for coolant hoses, you should find all the info needed to do the task. Be sure to flush your engine and radiator while its drained and refill with SCA additive and good commercial truck anti-freeze.
