Hosed, Cab heater plumbing questions
jetman10
swanville,maine
Got a question . I'm mounting my heater assy under the dash . I don't think this '66 deuce ever had a heater because there is no 4 inch hole thru the firewall or bolt holes in either fender apron. Anyway, where do I connect the two hoses to the engine ? There are two pipe plugs at the thermostat hsg area . But where does the other hose go ? Should be off the rear of the block shouldn't it ? Thanks .
