Hot breaks on M35A1
knissen
Jutland, Denmark
Hi all,
A few days ago I had the brakes adjusted in a workshop and checked.... everything seemed fine.
I was then out driving my M35A1 today - and the breaks got very hot, and ended up stuck! (as I stopped to check) I cooled them down, and loosened and drove to a workshop, with great mechanics who again cooled the brakes down, loosened the brake shoes and tested - everything worked fine... they moved freely, and were still able to brake the truck.
I then drove on, but again heated up the brakes, all six of them. I had the truck brought home on a flatbed.
My question is: What is the root course for this fault, wrongly adjusted brakes? dirty / rusty brake assemblies that makes it impossible for the brake shoes to disengage after braking, system building up pressure in the brakeline continiously (I dont know how?) or some other fault?
Any suggestion before I start to disassemble the brakes?
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
First I would have said something is out of adjustment, but all 6!? Have you checked the return spring on the peddle? I have seen these break or stretch allowing the peddle to bounce up and down and energize the system.
54reo
49
Chester IL
Re: RE: Hot breaks on M35A1
WillWagner said:
No freeplay in the brake pedal, a plugged M/C vent hole..
Agreed, check for free play/clearance in the master cylinder adjustable pushrod. Should be 1/2" (at the pedal) free play prior to any master cylinder piston movement.
tjcouch
Tampa, FL
I had the same problem - it was the airpack. If you open the "glad hand" on the driver side of the truck, and air comes out when the service brakes are NOT applied, you can chalk it up to the airpack sticking.
