hotstart block heater
rsh4364
15
greensprings ,ohio
just received my hotstart block heater for 85 m1009,its #TPS151GT10-000,has anyone installed one of these? was thinking about putting a t in lower rad. hose for input to heater,but heard something about a replacement freeze plug with a 5/8 nipple built onto it ..any advice or info very welcome,thanks Rick
MarcusOReallyus
816
Virginia
Not sure what your question is.
There are freeze plug types, which simply replace an existing freeze plug. No "nipple" that I know of. You just install it in place of the old freeze plug, then plug it in when you want to heat the block. Here's an example: http://www.amazon.com/Kats-11610-Wa...8145&sr=8-1&keywords=freeze+plug+block+heater
There are also heaters that go inline with one of your heater hoses. That would probably have something like a 5/8" nipple. Looks like that's what you have: http://www.amazon.com/Hotstart-TPS151GT10-000-Engine-Coolant-Heater/dp/B0006NZQQ4
If that's what you have, I don't tihnk it's going in your radiator hose.
Then there are the kind that go in your radiator hose. Here's an example: http://www.amazon.com/Kats-14600-Lo...47&sr=8-1&keywords=kats+block+heater+radiator
rsh4364
15
greensprings ,ohio
I looked at the other block heaters and liked the kimhotstart unit because it has a thermo-stat and its rebuildable,read mixed reveiws on the others,the directions are not vehicle specific and thought maybe someone on here may have installed on a cucv..this one needs input to be low on cooling system then output to heater core to circulate thru-out block, thanks for input guys.
Skinny
488
Portsmouth, NH
Sounds overly complicated. I have probably $75 total in a block and oil pan heater...absolutely no issues with cold starts. Tried and true, easy to install both. Search my threads if you want to know more.
As soon as I order a Jatonka grille cover, my rig will be artic proof.
