RustyInHouston
- 0
- 0
- Houston, TX
Gents,
URGENT HELP NEEDED I'm in Houston, and having a **** of a time with my MEP017a Generator. Can you reach out to your friends and help us?
I'm a marine engineer and have extensive experience with generators and power generation. I just need y'alls help in fixing the common gremlins.
We happen to be on high ground (planned
) but we now need my (broken) generator.
MEP017aSymptoms:
· Engine runs good, can maintain 60/61 HZ, but engine seems to "hunt" under zero load. (not uncommon)
· Voltage output at 208/120/3ph "dances" around 170v. Rheostat only changes voltage between 120v-170v
· I cannot get the 208 3ph that we need.
· Single phase operation is nearly impossible to get consistent 120v power.
· We have tried the "field flash" switch, and held it as long as 5 seconds (engine off)
· Fuel is good and reliable, we are burning 100LL (low-lead), and the engine is running good.
· We are now on an "island" and spares are not a possibility.
Help?
Rusty
832-510-6020
MEP017aSymptoms:
Help?
Rusty
832-510-6020
