- 5,580
- 345
- 83
- DESOTO, KANSAS
I just won a M809/M939 long bed cargo cover however this one states it is also extended height. When I was in the only extended height covers I saw were unit produced made up and usually two different fabric materials were used to make them. The last deuce I got had one and it was a Motor Sgt's ride and was the late 3 color top with green added on strips down each side and had a plywood rear wall with door. Pretty sure it is 20' long but how high/tall?
So does anybody know how much it was extended?
Only thing I have found is
Cover, Fitted, Vehicular Body, also referenced with federal logistics item name code 22374 - A fabricated removable textile item specifically designed to inclose or partially inclose vehicle body(ies), for the protection of cargo and/or personnel, from the elements. it may have opening(s) and/or windows of transparent material. see also cover (as modified) and top assembly, truck body, detachable. excludes tarpaulin and curtain, vehicular.
Cover, Fitted, Vehicular | 2540-01-460-9165 | 12450242-7 | Long Cargo Body / Extended Height | Tan |
