I've lifted the body of my Humvee three inches because I am installing a turbo diesel and the civi hummers got a one inch lift when this happened. Without any lift I would have had about 1/2" clearance between the bottom of the cowel and the top of my center intake manifold. I figured that three inches would be as easy as a one inch lift and I might want to install larger tires at some point, but I do have to have longer P/S and Hydroboost hoses made up. I went to place that sells all types of metal and found an aluminum dowell in the scrap pile and had them cut it to size and drill a hole in each of the six pieces. It cost me about $125. Then I bought longer bolts. The bolt that is at the left front position is the most difficult to deal with. you cant get away with a bolt that is extra long at this spot. I haven't make any lift brackets for the hood hinges yet, but they should be really easy and I also have to lengthen the fuel tank brackets. I have also raised the rear bumper to increase clearance. Be carefull when lifting the body as there is a built in flex point at the rear of the door/wheel well area. That slot is to allow for frame flex without damaging the aluminum body, so lift it slowly and carefully.
