The Swamphare
- 0
- 0
- Hudson, WI
I just replaced the glow plugs and they don't cycle. How do I proceed?
Thank you.Leaving the hubs locked in adds excessive wear on front differential, front u-joints (axles and propeller shaft), and most likely some wear in the transfer case since that transfer wasn't designed for full-time 4x4 (even if not put in 4x4 in transfer case. I used to have a civy full-time 4x4 square body Chevy and the front parts wore fast and gobbled gasoline. Probably best to unlock hubs.
The '09 has to have the controller card as well being it is the same engine. Definitely want to dig into the TM. There are also threads on this subject that are very helpful and can be found using the search bar.
Hey, thanks Tinstar! There seems to be a number of folks that advocate a bypass operation with a button installation... What are your thoughts?
