m1garand_man
- 0
- 0
- Ft Wainwright / AK
I am planning on reringing my 6.2 pistons while I have the heads off. This is because of three reasons. 1 I am trying to eliminate a smoke on start up issue out of the left bank and two no shop in town will touch my block because they are afraid of cracking it and three because I don't have the $5k I am being quoted to rebuild the lower end if they would touch it.
My bores are all 3.974-3.976 so I should be able to use standard sized rings. The engine was a boyce pull out with 18k on it that was put in 20k ago but has fine pitting in the #2 cylinder which I believe has worn the rings on that piston causing my smoking on start up.
So my question is how do perfect circle brand rings compare to sealed power? I am asking because they are about a quarter of the cost.
Additionally how critical is it that I replace the rod bearings? I don't want to deal with fitment issues since I don't plan on having the crank out of the truck to have it polished.
The concerning thing with the sealed power rings is that it looks like there are only three rings per piston not four.
http://www.oreillyauto.com/site/c/d...91_-1&keyword=piston+rings&pt=03383&ppt=C0365
