how do you hook up tow bar axel chains
gem1410
44
TOMS RIVER NJ 08527
have to tow an m35a2 with a built up front bumper with no place to hook up a tow bar--i purchased the axel chains and towed an m35 last week but noticed the chain assembles slide back and forth about 3 inches--is this common and what is the proper hook up for the chains--thanks george
Barrman
1,734
Giddings, Texas
I have used the chains both inside the leaf springs and outside the springs. Outside requires the brake lines to be moved out of the way. It tows better with them wider apart on the outside as well.
I have never had the axle wraps move any. Granted, I have only towed about 300 miles with them on 3 different vehicles, but they didn't move.
gem1410
44
TOMS RIVER NJ 08527
Thank you both for your help--the tm was what i needed--good luck with your trucks ---- when you tow do you need someone inside the truck being towed to assist on sharp turns
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I usually air the front tires to 65. Sometimes when not on pavement, help is needed, but usually no help once on paved roads. I try to plan on wide turns. Sharp turns do lock up the steering.
CARNAC
The Envelope Please.
636
Corpus Christi, TX
A couple questions:
What is your towing vehicle?
How far are you going?
Does NJ law allows a person to be in the towed vehicle? Maybe I'm reading it wrong. Do you mean someone to hop in...say at the end of the street to help make a turn there versus riding in the towed vehicle the whole time?
You're not too far from Lakehurst/Ft Dix (I use to live in Old Bridge).
1,176
Gem, are you getting these from Lakehurst? I won a truck(cucv) there and I'm looking for someone to look it over and or maybe even retreive it for me. EUC should be soon.
gem1410
44
TOMS RIVER NJ 08527
Towed the truck home today--steering was stiff as this truck is kind of beat up--bought it for parts--made it home no problem--40 miles-------thank you all very much----i am going to lakehurst tomorrow--what did you get--i can take a look at it and tell you if its driveable or not--call me tomorrow around 10am--george--732-581-9058
