- 706
- 975
- 93
- Southern Minnesota
I've been starting to go over my new, to me, M998. One thing I've noticed, a lot of the boots around the electrical connectors are cracked. (The wires and the pin and socks seem to be just fine, it's only the boots.)
Can the boot be replaced without having to remove the pin from wiring? Is there enough room if you remove the C-clip from the pin to pull the boot off and just replace it?
Any help or pointers to examples of how to fix these properly would be helpful. All of the lighting boots under the hood, and one in the rear are cracked to the point I'm worried about it letting in water to the connections.
