how do you run a front winch AND a hydraulic pump together?
dma251
15
Arlington, Washington
I'm bouncing around the idea of getting a knuckle crane like cranetruck did for my M813.
How do I run my front winch AND the hydraulic pump off my pto? Do I have to convert my front winch to hydraulic drive?
Any specific cranes I should be looking for? What are the advantages of the HEMTT style telescoping versus the HIAB style that folds up?
dma251
15
So I would engage the pto, but keep the winch clutch in neutral up at the winch? When the pump was running the winch driveshaft would be turning?
Is it hard to mate pumps up to the pto? Will I need to change out my pto to do this?
Lots of questions.... Thanks for the help.
gringeltaube
Staff Member
2,432
Montevideo/Uruguay
dma251": So I would engage the pto, but keep the winch clutch in neutral up at the winch? When the pump was running the winch drive shaft would be turning?
No, all you need is a dual output PTO + lever&linkage. Both functions are independent. You can run a pump off the rear and having the front output in neutral position for as long as you want. And viceversa. Or even at the same time if you have eyes, ears and hands enough to attend everything that's happening or could happen...! :shock:
No, find the correct yokes for output and pump shaft and connect them via a propeller shaft.
Hope it helps.
cranetruck
75
Meadows of Dan, Virginia
The wrecker version of your truck has a rear winch, which is powered from the power divider, perhaps you can adopt the same set-up for your cargo.
Not sure how the rpm would be set for the hydraulic pump, though.
About advantages/disadvantages, the Grove crane is more compact hight-wise and is more like a regular crane found on the wreckers.
The HIAB style is like an arm extension of yourself, extremely flexible. On my truck, I can place cargo within a foot of the crane pedestal or 26 feet away and manuever loads with great precision. Lifting capacity is about the same. IMHO, the HIAB wins hands down (pun intended). :)
73m819
319
gainesville, ga.
GT is right, get a 5t dump pto, this a duel fuction pto, this would be the easyest and cheapest, and safest, the pto on a dump is connected to the dump hyd.pump by a drive shaft
derby
S.E. MI.
You could also get the pto and pump off of an M812 A1 bridge truck.It will have alot of the parts you will need,tank,pump,dual out put pto,hoses,filter housing and even a rear hydraulic winch.
73m819
319
gainesville, ga.
dosent the m812a1 bridge truck hydraulics run off a transfer case pto
m139h2otruck
NH
We have an M812A1, and the hydraulic system is powered off the same PTO gear box as the front winch (just like in the picture above). I also want to install a crane, and plan to use the pump setup on the truck as it was built for the power source. In the tech manual section is a manual for the bridge trucks in this series that is a good read if anyone is bored.
