How does the multifuel engine actually work?
WyoDeuce
Laramie WY 7220 ft.
Extremely high compression (~27:1) and extra attention paid to the fuel atomization/spray pattern help to burn different fuels. There is also a fuel density compensator to help with the air/fuel ratio. There is probably also some secret magic voodoo mixed in somewhere.:twisted:
NDT
7,333
Camp Wood/LC, TX
In a nutshell: The injector squirts a stream of fuel into a cup in the top of the piston. As it evaporates from the cup, it burns and expands, pushing the piston down. Conventional diesels inject a mist into the cylinder that burns immediately. The evaporation lag is what allows the engine to burn "hot" fuels such as gasoline, without detonation, or the fuel exploding rather than burning. M.A.N., a German company, invented this engine design. Continental called it "Hypercycle".
area52
San Bernardino CA
And they are still mult-fuel even with the fuel density compensator bypassed!! Its mostly in the way the piston/combustion chamber is designed.
1,159
Do a search for the word "hypercycle"-all your questions shall find answers.
tennmogger
556
Greenback, TN
So, my old Ford with a 7.3 indirect injected Diesel, 22 to 1 compression, seems to meet those simple specs. Is it therefore a multi-fuel? There has to be more to it. yeah, I know, search, which I shall......
Josh
12
Portland, Oregon
Your IDI can handle thinker fuels like WMO, but not thin fuels like gas. Put gas in that engine and your going to need a new one.
frank8003
4,989
Ft. Lauderdale, Florida
After all these years the new cars use it now, albeit much more sophisticated,
but same same GI.
Would you like to see the patent?
One notices that there is no diesel clanking and banging and nasty noises,
just sweet power from almost anything that will burn.
"Tiss a proper diesel engine.
And I would believe almost anything David Doyle would write but all links broke.
